Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2019 Damper Rods In Pre-2018  (Read 2297 times)
Offline hondamxracer
« on: June 23, 2019, 10:56:48 PM »
Does anyone know if the 2019 damper rods which are 10mm longer can be installed in 2015 forks?
https://advrider.com/f/threads/honda-cb500x.840842/page-886#post-37853092
« Last Edit: June 23, 2019, 10:59:35 PM by hondamxracer »
Re: 2019 Damper Rods In Pre-2018
« Reply #1 on: June 24, 2019, 10:01:12 AM »
Yes they are a direct fit - I also suggest to use the matching springs from a '19 bike if you're not going for weight matched aftermarket linear springs. They (the 19 oem springs) are 5.5N/mm initially and have a much less harsh transition to the harder part at about 130mm travel (including preload) matching the damper rods much better than earlier springs.
« Last Edit: June 24, 2019, 10:05:58 AM by Oyabun »
« Reply #2 on: June 24, 2019, 03:12:27 PM »
I was thinking about pairing the 19 dampers with some race tech springs
« Reply #3 on: June 24, 2019, 05:54:02 PM »
*Originally Posted by hondamxracer [+]
for info. If you buy the 2019 LEVEL 1 fork kit from Rally-Raid, you'll get their 2019 length dampers, plus proper shim-valve damping and longer linear wound springs (which eliminate the crappy plastic spacer). You'd have a proper matched set-up then.
« Reply #4 on: July 22, 2019, 12:52:51 AM »
My 2019 springs and dampers will be in this week. Should i stick with the 10 wt oil?
I read that the stock oil level measurement (spring removed, damper installed, fork compressed) is 160mm. Would you recommend sticking with this?
Any idea how many CCs 160 measures out to?
« Reply #5 on: July 22, 2019, 01:05:01 PM »
I have mixed 10w and 15w fork oil for a roughly 12.5w viscosity. You'll need avout 470-ish ml per fork leg to get to about 160mm air gap.
« Reply #6 on: July 22, 2019, 01:36:32 PM »
What brand of oil are you using?
« Reply #7 on: July 22, 2019, 02:00:29 PM »
I'm using ENI in damper rod forks as that's what I have easy access to and have great performance/cost factor.
I tend t use Fuchs Silkolene in cartridge forks which I've found the best available, but that's quite a bit more expensive and harder to come by where I live.
« Reply #8 on: July 24, 2019, 03:45:06 AM »
Thanks!
I installed the 2019 dampers today. I can confirm you do get 10mm of rise.
I drained the oil from both fork legs into a ratio-rite measuring cup and both legs measured just under 450cc. Should I put 450cc back in or the 470cc noted above?
« Last Edit: July 24, 2019, 03:48:32 AM by hondamxracer »
« Reply #9 on: July 24, 2019, 05:41:06 AM »
Fill until you get about 160mm air gap.
