Author Topic: 2019 Accessories  (Read 9165 times)
Re: 2019 Accessories
Reply #40 on: September 06, 2019, 09:48:57 PM
Center stand on- Honda quality nice to have-first thing I noticed on the stand is coolant tank was empty-will pick some up in the morning
Offline JM83
Reply #41 on: September 07, 2019, 10:26:44 AM
*Originally Posted by adman [+]
Yes, in the 2019 model, a cable with an open plug is already installed in the wiring harness. It lies on the left under the side panel and is controlled by the ignition. If the socket is to work without ignition, a new cable must be connected, which is connected directly to the battery. That's the way it is with the CB in Germany, if that applies to all countries, I can not say.
Perfect. Thanks so much for this information. I live in Belgium so must me the same. Cheers.
Last Edit: September 07, 2019, 10:27:20 AM by JM83
Offline Long Ride
  • Don't Let Up
  • Bike: 2019 CB500X ABS
Reply #42 on: November 30, 2019, 02:29:35 PM
As of this day the centerstand is available in the USA for the 2019-- I just ordered one - no back order-should have it Friday- $150
Does anyone know if the circuit for the OEM 2019 12v accessory outlet switched or is it always hot?
Long Ride
Online adman
  • Bike: CB 500X PC64
Reply #43 on: November 30, 2019, 02:54:16 PM
Works only with ignition. (Europe Model)
Offline Long Ride
  • Don't Let Up
Reply #44 on: November 30, 2019, 03:03:44 PM
Thanks so much adman.
I'm trying to get the side fairing off I have removed the 4 screws and push-pin type connector removed along with the two Velcro tabs disconnected... but cannot for the life of me get it to come off. One video said to loosen the two 5mm bots homing what appears to be the dash in place but that doesn't seem to affect it. I don't want to damage this thing so am I supposed to pull out? up? forward or backward? Any hints?
Long Ride
Offline Long Ride
  • Don't Let Up
Reply #45 on: November 30, 2019, 03:13:36 PM
...update: never mind. It has two clips connecting to the front cowl that pull directly out and a third at the top near the dash screw I loosened and it pretty much fell off in my hand. It's always so easy when you know what you're doing.
"It's an art form...If you don't know what you're doing you art not do it."
Long Ride
Offline racer
Reply #46 on: November 30, 2019, 04:28:32 PM
Switched on my 2019.   Racer
Offline Kambo
  • Bike: CB 500X
Reply #47 on: December 01, 2019, 09:13:07 AM
*Originally Posted by japes1275 [+]
There are some 2019 specific accessories but they are difficult to find. They are on the Honda UK site somewhere so you could try there.
The 12v socket is about £120 and the heated grips are £450 so you might want to try aftermarket!!
Iíve gone for a set of OEM heated grips for an earlier Honda for £85 - I had them on my old X and they looked and worked fine.
Wow, I've literally just ordered my '19 bike and requested there 12v socket and it was showing as £25, he didn't query it and there wasn't any deals on from what I could see but thats a crazy difference from July to December!
*Originally Posted by Shaky6 [+]
Talked to USA Honda today.  They don't have any good excuses for why they're so behind on accessories.  The 12V socket is now pushed back to Sept 30.
Did you get this in the end, if not just get it from the UK, might work out cheaper even with shipping across the pond
Offline Flashp
Reply #48 on: December 13, 2019, 11:42:59 PM
£25 for the 12V socket is parts only. Honda have the fitting at £50. Fingers crossed you get free fitting  :046:
Offline Addy
Reply #49 on: December 14, 2019, 11:07:09 AM
How often do they throw in a free fitting for something like that? Not very often, right?
