Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: On the road and hearing a disturbing sound  (Read 2108 times)
« on: July 08, 2019, 11:30:06 PM »
I'm in Warren, PA on my way to CO, and when I stopped this evening I noticed a growl or vibration when I rev the engine.  It seems to be coming from the area of the dash. I tried uploading a WAV file, but I wasn't able to.  I'm going to try sharing it through dropbox.  I'm trying to determine how serious this might be.
https://www.dropbox.com/sh/jkby8kqmkpm1xp2/AAAAgU7iwzS1NW850zLT8jkqa?dl=0
Offline harryhendo
Re: On the road and hearing a disturbing sound
« Reply #1 on: July 09, 2019, 02:57:09 AM »
Have you removed any body panels recently? It sounds like one of the panel's prongs may not be firmly seated into its respective plug.
Also, if you did a recent oil change, check the engine guard under the engine, which at least I had to remove to get a good purchase on the oil filter.
Also check the windshield bolts for tightness (3 lbs. torque setting... a bit tight but not too tight).
« Reply #2 on: July 09, 2019, 03:25:44 AM »
*Originally Posted by harryhendo [+]
Thanks, Harry. I have removed the panels, so I'll check those again.  I tried to stop the sound by holding onto various pieces fairings and the windshield, but nothing seemed to work. I don't have an engine guard.  I'll try again when it is light out.
Offline hilldweller
  • City / Town: Macclesfield
« Reply #3 on: July 09, 2019, 12:21:14 PM »
I noticed a grow
There's a tiger in your tank.
Am I the only one old enough to remember that advert ?
Brian.
« Reply #4 on: July 09, 2019, 12:26:57 PM »
I remember it! Except it is not in my tank :(
Offline hilldweller
« Reply #5 on: July 09, 2019, 04:16:17 PM »
I've just remembered a really odd vibration I had, I eventually traced it to a satnav charger connector when the satnav was removed. The pronged charge plug was a plastic clip in unit and it was loose enough to make noise at some revs, amplified by the plastic frame.
During the same exercise I found a missing rubber grommet for a side panel, I must have pushed it through when refitting. Now I've put silicon grease on them all to prevent this.
Brian.
« Reply #6 on: July 09, 2019, 05:57:42 PM »
Are those are the grommets you find on the garage floor after you've reinstalled your side panels? :008:
« Reply #7 on: July 09, 2019, 06:07:23 PM »
It sounds like angry ants to me....ask Bern-Grt :745:
seriously though, it sounds like a clip is out somewhere, or a screw is missing from the radiator cowling etc. Sorry I can't be more specific
Offline hilldweller
« Reply #8 on: July 09, 2019, 06:46:50 PM »
That's the one.
Brian.
« Reply #9 on: July 09, 2019, 06:50:54 PM »
That's the one.
I've now glued mine in with a tiny blob of superglue....sick of seeing them rolling somewhere hard to reach :191:
