Author Topic: Fill up time.  (Read 2159 times)
Offline Mence
Fill up time.
on: July 09, 2019, 06:49:46 AM
Hi all, X wants fuel, fine.
Any benfits to using the higher grade fuel in UK pumps?
I don't normally ponder this but as the X is so frugal, paying the extra isn't a problem at all.
Ta very much for input.
Offline Martin
Re: Fill up time.
Reply #1 on: July 09, 2019, 08:51:38 AM
Hi,
I've accidentally filled up a few times with the higher grade fuel, but I notice absolutely no difference in either how smooth the engine runs (it runs smoothly regardless!) nor fuel consumption (I get around 85 mpg, imperial gallons).
I would save the 5p/l and ride more  :002:
Offline Mence
Re: Fill up time.
Reply #2 on: July 09, 2019, 09:58:13 AM
Sounds good to me, thanks.
Offline Marv_
Re: Fill up time.
Reply #3 on: July 09, 2019, 11:49:49 AM
I've ran mine on V-Power a number of times and I do seem to get about 5mpg more out of a tank. (Which doesn't cover the extra cost) in theory the additive pack they put with v-power should keep the fuel system cleaner.
No noticeable additional power.
Offline Mence
Re: Fill up time.
Reply #4 on: July 09, 2019, 01:46:58 PM
No problem.
Don't expect any more power, just wondering if it may make the power delivery a little smootner.
I guess Honda have engineered it so it doesn't matter.
Offline harryhendo
Re: Fill up time.
Reply #5 on: July 09, 2019, 05:55:27 PM
I've found no difference between "regular" and "premium" when I've used both in the US. Seems like premium is just a way to burn up money.
Re: Fill up time.
Reply #6 on: July 09, 2019, 06:54:20 PM
*Originally Posted by Mence [+]
Any benfits to using the higher grade fuel in UK pumps?.....
Only if you work for an Oil company and are on profits share.
Far better to spend the money saved on loose women and/or Ginsters pasties
Offline Mence
Re: Fill up time.
Reply #7 on: July 09, 2019, 07:12:59 PM
Cheers guys, that's confirmed it.
Jonathan, sounds ideal to me...
Online motorboy
Re: Fill up time.
Reply #8 on: July 09, 2019, 10:42:45 PM
Let me throw this out there-but I'm talking about 2019X in the USA only-when I first got the bike I knew the added mid range might be hard to feel and it felt soft less power comparing it to my 2014X so after 600 miles and first oil change I stated to get into it a little and heard engine rattle at 6,000 rpm up- not a big surprise with the crap gas we have and with temps in the mid 90's F so I tanked up with premium 93 octane to mix with the half tank of regular I had - I found the missing power and a way better running engine so I will be running mid grade from now on at lease till the temp's go down in the fall
Offline Buster217
Re: Fill up time.
Reply #9 on: July 10, 2019, 07:44:25 AM
If your engine is knocking or otherwise running poorly there is something wrong. I suppose it could be crap gas but if you got it at a name brand station with a decent sales volume I kinda doubt it.
