Author Topic: Aux lighting kit  (Read 1031 times)
Offline Mence
  • Bike: 2017 CB500X
Re: Aux lighting kit
Reply #1 on: July 09, 2019, 07:39:22 PM
*Originally Posted by Mence [+]
never used one, but it looks OK in the pics. My only gripe with off the peg looms is that they're usually longer than necessary and you may end up chipping it back to suit.
If you don't mind cabling and electrickery it's pretty easy to make up your own loom with terminals, connectors etc, if you have some cable strippers/crimping tool and a soldering iron...it'd cost you around the same (possibly a bit more) than the one you've linked to, but chances are it'd be better quality. Plus if you buy the tools, they always come in handy for future farkles...
these are ace...https://www.ebay.co.uk/itm/Yato-Professional-Automatic-Electrical-Cable-Wire-Stripper-Cutter-CrimperYT-2313/222793540528?_trkparms=aid%3D333200%26algo%3DCOMP.MBE%26ao%3D2%26asc%3D20171012094517%26meid%3Dd9427011f32b407ea96c977afeec9639%26pid%3D100008%26rk%3D4%26rkt%3D12%26sd%3D173908782533%26itm%3D222793540528&_trksid=p2047675.c100008.m2219
if you're not happy wiring, then 34 aint bad for a plug and play....but check that the connectors are compatible with your lights
Last Edit: July 09, 2019, 07:42:26 PM by Jonathan
Offline Mence
  • Bike: 2017 CB500X
Reply #2 on: July 09, 2019, 07:54:15 PM
Cheers Jonathan
Reason I ask is because I am pants at wiring and would probably do more harm than good if I tried. :232:
Reply #3 on: July 10, 2019, 09:24:28 PM
Cheers Jonathan
there's only one way to become un-pants....but if it's a real chore then maybe best to buy a ready made
Reply #4 on: July 10, 2019, 09:55:20 PM
Do a search on here. Lots of resources available, including my thread for mini LED lights that has over 40,000 hits. Use the search function to your advantage.
Offline Mence
  • Bike: 2017 CB500X
Reply #5 on: July 11, 2019, 06:50:47 AM
Will do fella, apologies
