Author Topic: Rear top box  (Read 2687 times)
Offline Borsato
Rear top box
on: August 13, 2019, 12:22:59 PM
Does the Givi top box come with its own rack underneath or do I have to buy a separate rack. Cant seem to find the answer. Thanks.
Offline Lancs-lad
Re: Rear top box
Reply #1 on: August 13, 2019, 12:46:59 PM
You have to get a rack, either Givi or maybe SW Motechs Alu-rack which needs an adapter plate to mount many makes of top box.
Red Rose Classic MCC
Re: Rear top box
Reply #2 on: August 13, 2019, 02:42:54 PM
The Monolock series comes with it's own base and will bolt up to any rack that excepts any Givi base
Re: Rear top box
Reply #3 on: August 14, 2019, 10:52:56 AM
*Originally Posted by Borsato [+]
Givi do two main types of case MonoLOCK and MonoKEY....each requires a specific rack plate. Later V type cases also require V type fittings...best to buy secondhand as a complete set up
Last Edit: August 14, 2019, 10:53:38 AM by Jonathan
Offline choyashi
  • Ex Member
Re: Rear top box
Reply #4 on: August 16, 2019, 06:01:03 PM
Do what I did........
I got the Givi top case mount, without a base plate.
Then used a Shad top case, which comes with it's own
base plate.
This was the cheapest way to go... :016:
Givi rack part# is : Givi 1121FZ Top Case Support Bracket Kit Honda CB500X 2013-2019
Last Edit: August 16, 2019, 06:11:44 PM by choyashi
Offline Manolis
  • Country: 00
Re: Rear top box
Reply #5 on: August 27, 2019, 05:34:52 PM
I am planning to buy a Givi V47 and i am afraid that it will be too big for this bike...
Honda suggest a 35L top box.
If someone has the same top case, Givi V47, i will be pleased to see a picture.
Thanks!
Re: Rear top box
Reply #6 on: August 27, 2019, 06:12:18 PM
*Originally Posted by Manolis [+]
Thanks!
I have a V47, and I think it is the perfect size.
Re: Rear top box
Reply #7 on: August 27, 2019, 06:18:02 PM
Thanks!
Here is a picture of the V47 with my helmet in it.
Offline Manolis
  • Country: 00
Re: Rear top box
Reply #8 on: August 27, 2019, 06:55:23 PM
Thanks for your reply!!
Nice bike!!
Offline Topo
Re: Rear top box
Reply #9 on: September 12, 2019, 09:55:19 PM
Did you ever get the 47? I've just picked up my new CB and would rather not strap a milk crate to it ;) The dude who posted a pic of his, also had side cases. I wonder if the 47 would seem too huge without those.  Seems these top cases are quite expensive. Anyway...any experience you can share would be appreciated.
