Basic Search
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Low speed - jumpy & mushy 6 speed  (Read 1184 times)
Offline brazilusa
  • City / Town: WEST BLOOMFIELD
« on: September 21, 2019, 07:56:57 PM »
I am an old school rider and riding for 40 years. I have a few miles on my CB500X and the 6 speed is mushy and it's jittery at low speeds. I had hopes of taking some off-road adventures but with both these factors...I am not happy with it. Does anyone have any thoughts on these two issues?
Offline drjack
  • Bike: 2016 CB500X
  • City / Town: Lawrence, KS
Re: Low speed - jumpy & mushy 6 speed
« Reply #1 on: September 21, 2019, 08:35:11 PM »
I haven't had issues with the transmission being mushy. It did take me awhile to get used to keeping the RPMs up off-road as the X doesn't like being lugged down low.
Jack
The intelligent rider uses a quiet pipe.
Offline brazilusa
« Reply #2 on: September 21, 2019, 08:56:54 PM »
If I shift down from 5th or 6th at a stop light. It won't go into gear...drop it to 1st but it gets stuck in neutral. Then finally thunks to 1st or I lug it in 2nd gear. Never had a bike do this. Embarrassing.
The low speed jitter...the motor wants to go but the clutch isn't great. Not fun in gravel and slow speeds.
Offline Sweeper
  • Bike: 14 CB500x
  • City / Town: Hartselle,AL
« Reply #3 on: September 21, 2019, 09:18:00 PM »
Check the adjustment on your cable and be sure it is completely disengaging. These bikes are normally very smooth shifting. The adjustment doesn't have to be far off to be a problem.
Offline drjack
  • Bike: 2016 CB500X
« Reply #4 on: September 21, 2019, 09:41:39 PM »
Yep, sounds like a clutch adjustment issue. I don't have any problems in mud/dirt/gravel, I can ease on the throttle and it moves or I can rip it and spin anytime. As for shifting down from 6th after stopping, I have experienced that on the X and a couple of other bikes. I just make sure I'm downshifting as I slow down. I don't usually let out the clutch between down shifts either, just find it easier to downshift while rolling.
Jack
Offline brazilusa
« Reply #5 on: September 22, 2019, 03:27:47 AM »
Happens most on an incline stop, where I'm decelerating to stop on a hill. Just won't go into first. I'll check out the clutch and see if it works.
« Reply #6 on: September 22, 2019, 03:31:22 AM »
You didn't say what year it is--because 2013-2015 the trans didn't always down shift well-2016-2018 parts improved better but still not great- 2019 fixed butter smooth-regardless of year the clutch free play has to to right no more than 20mm measured at the end of the lever and full syn oil helps
Offline brazilusa
« Reply #7 on: September 22, 2019, 02:33:39 PM »
It's a 2015, had 0 miles.
« Reply #8 on: September 22, 2019, 02:47:29 PM »
*Originally Posted by brazilusa [+]
[/quote
You need to put miles on the bike a few thousand-every part needs to break in it will improve to a point- than if it's not right  you can look into maybe something needs fixing or adjusting- but I doubt anythings wrong just a new bike that you need to get use to
Offline Xchemie
  • Bike: 2018 CB500X
  • City / Town: Lockport, IL USA
« Reply #9 on: September 23, 2019, 03:17:02 PM »
My 2018 was a little stiff shifting for the first 2k miles. Smooth after that though. But agree with checking your clutch free play as well.
