Author Topic: Sudden loss of clutch cable pressure  (Read 500 times)
Offline sohlman
on: December 10, 2019, 04:49:35 PM
Hi relatively new to riding. Today on my commute I suddenly lost all clutch cable pressure (couldnít get out of gear). I was able to adjust the lever quite significantly and it seems fine. I am curious though what would cause this sudden loss of pressure?
Online Oyabun
Re: Sudden loss of clutch cable pressure
Reply #1 on: December 10, 2019, 07:13:54 PM
Which year your bike is? Older (pre 29 bikes sometimes had a problem of the clutch actuator arm bushing/bearing falling off from their original location and let the arm go off center. This releases tension and moves the friction point from a bushing to the engine side case - resulting in loss of tension and after a while a failure of the oil ring at the top of the engine case.
More info and picture sof the clutch actuator arm and clutch side engine casing can help diagnosing the issue.
Offline sohlman
Reply #2 on: December 10, 2019, 09:59:44 PM
So itís a 2014. Hope these pictures help.
https://imgur.com/gallery/aGIr3Ap
Reply #3 on: December 11, 2019, 12:58:21 AM
Yes- being it's a 2014 no doubt about it the bushing has fallen-search this problem and you will see a few different ways of fixing it
