Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
Contact Us
Please
login
or
register
Honda CB500X
Accessories, Mods, Products, and Clothing
Modifications, Accessories, and Appearance
Just fitted a Powerbronze front fender extender and rear hugger MY19
21 Jan 21, 09:08 AM
Pages: [
1
2
Go Down
Author
Topic: Just fitted a Powerbronze front fender extender and rear hugger MY19 (Read 2791 times)
Kambo
CB500X Member
Topic Author
Bike: CB 500X
Country:
on:
December 25, 2019, 11:10:29 PM
And I have to say I am impressed with both the quality and fitment, coverage is obviously good as longer drop
I've only had pyramid plastics stuff before on my other hondas or triumphs or yamahas so never looked at anything else but there is a new one in town now for me
Logged
woody
CB500X Master
Bike: CB500X
Country:
Re: Just fitted a Powerbronze front fender extender and rear hugger MY19
Reply #1 on:
December 26, 2019, 06:53:14 AM
I agree with you, I have a powerbronze hugger and pyramid fender extender on MY18, powerbronze is good stuff
Last Edit: December 26, 2019, 06:53:54 AM by woody
Logged
adman
CB500X Pro
Bike: CB 500X PC64
Country:
Reply #2 on:
December 26, 2019, 11:23:50 AM
Could you please show photos of it? I am also interested in these parts.
Thank you.
Logged
Flashp
CB500X Pro
Country:
Reply #3 on:
January 02, 2020, 07:34:03 AM
Originally Posted by
Kambo
I'd like to see some photos if you could?
Thanks
Logged
Flashp
CB500X Pro
Country:
Reply #4 on:
January 16, 2020, 10:11:36 PM
I'm in the process of fitting these parts. I'm going to paint the bracket for the rear hugger, it's quite a lump of brightly plated metal to go around a black swing arm
Not sure what an alternative would have looked like but this affair looks over the top. Not sure how obscured it'll be by the silencer given you have to take it off to fit this.
My own preference would have been not to have the silver mesh panel in the chain side. This is going to get removed and painted black and re-fitted. Ambersil Label and glue remover will be first choice as I don't want to distort the mesh if I can help it.
I think the rear hugger is expensive for what it is when you have a close look at it and how 'neatly' it's been trimmed in places. I'm hoping it'll look better with a bit of paint and fettling.
I decided I'm going use 3M VHB tape for the fender extender, I really don't want holes in it.
I've not held this up to the bike, hoping it's not going to look like a comedy nose
Last Edit: January 16, 2020, 10:13:48 PM by Flashp
Logged
Falang
CB500X Member
Country:
Reply #5 on:
January 16, 2020, 11:57:25 PM
Flashp
I decided I'm going use 3M VHB tape for the fender extender, I really don't want holes in it. I've not held this up to the bike, hoping it's not going to look like a comedy nose
The VHB tape works well provided you hold it tight overnight while it cures; you won't need holes. I had a fender extender stuck on a BMW for 18 years and it never fell off. A good way to hold it tight while the tape cures is to use a squishy silicone ball. A “Wahu Super Grip Skimball" toy works perfectly. First stick the fender extender in place finger tight, then insert the ball between the front tire and the front fender at the front of the bike. Turn the front wheel backward until the ball sits between the tire and the upper part of the fender extender where the VHB tape is. Leave it overnight for the tape to cure. In the morning, turn the wheel the other way until the ball rolls back out. A few days later I used black RTV to fill in the small gap between the fender extender and the fender so there is zero free play at the edges—a belt and suspenders approach.
Now the radiator stays clean when riding in mud and it’s much easier to wash the front of the engine. Bike makers ought to make their fenders this long in the first place, like they used to in the 1970s, e.g. Honda CB350, BMW R75.
I got this one off eBay
https://www.ebay.com.sg/usr/moto-roar?ul_noapp=true
Last Edit: January 17, 2020, 12:01:27 AM by Falang
Logged
Flashp
CB500X Pro
Country:
Reply #6 on:
January 17, 2020, 08:21:08 AM
Good tip on keeping pressure applied using a ball, I have just the thing for that and a good idea on filling in the gap for a neat finish
Logged
Flashp
CB500X Pro
Country:
Reply #7 on:
January 17, 2020, 10:11:16 PM
Well I had an interesting afternoon.
The mud guard extender didn't fit properly, not even close to matching the profile of the part on the bike. Apparently they discovered the same today when a development bike arrived.
The hugger has an issue with the bracket that goes around the arm in that there's not really enough room with decent clearance for the brake line.
This metalwork is on the underside which is more or less where the bracket wants to go:
So, it's all going back for a refund. Neither of these parts are as well developed as they should be.
The metalwork for the hugger is hideous. It would be far better picking up on the two original fixings on the chain side and then bonding to the swing arm with VHB tape or similar. I'm going to wait for Honda to do release parts I think.
Logged
Flashp
CB500X Pro
Country:
Reply #8 on:
February 14, 2020, 11:36:51 PM
Bit of update available for this and some good news for me at least.
The Powerbronze parts weren't working for me, the hugger was too bulbous and the fixing metalwork that attached to the swingarm wasn't appealing to me at all.
And I mustn't forget to mention that they don't have a correctly fitting front mudguard extender in the product range, the 2019 bike version has yet to be designed.
I found parts from Pyramid Plastics from this retailer:
https://www.motorcyclepartswarehouse.co.uk/pyramid-rear-hugger-extension-fitting-kit-honda-cb-500-x-2019.html
https://www.motorcyclepartswarehouse.co.uk/pyramid-front-fender-extender-extenda-fenda-honda-cb-500-x-2019.html
A little cheaper for both parts, they both fit well and they fit in well with the bikes original plastics in terms of finish and design.
The rear hugger is secured with a substantial cable tie which is both discreet and really is all that is necessary since the molded profile fits the swingarm well. It won't be going anywhere anytime soon.
The mudguard extended I chose to secure only with the supplied pads which are also of a very good quality although you get four plastic rivets as well. I took the mudguard off to do this and in the process I discovered that the brace that it fixes to had picked up a lot of stone chipping in only a few hundred miles so I cleaned it up and gave it a couple of coats of gravel guard since it's steel and it may help prevent some rusting down the line. I also sealed up the joint from the inside to prevent long term ingress of water and dirt having any effect on the bonding tape.
Last Edit: February 14, 2020, 11:54:04 PM by Flashp
Logged
Steve T
CB500X Pro
Bike: CB5X,F8GS,600Alp
Country:
Reply #9 on:
February 15, 2020, 12:01:59 PM
Just fitted both of those items to my new CB5X (the Pyramid plastics, not the Powerbronze stuff).
Unlike yourself I'm not impressed with the retention system for the rear hugger - one large tiewrap just goesn't seem enough to me as it leaves a little movement of the hugger when fitted to the bike. I adapted mine by fitting a drop down section of hard plastic sheet, to prevent road dirt from the rear wheel hitting the suspension linkage. It works a treat, as does the hugger itself in keeping most of the road dirt off of the upper section of the rear shock.
The front I secured with 3 M5 stainless steel bolts - my faith in 4 small plastic rivets and a load of sticky pads would have been very small
. When fitting I used lashing of silicone to help keep it all together and fill any gaps to help prevent the ingress of dirt.
Tried the bike out yesterday with both fitted and whilst the rear appeared to do its job, the front still allows loads of road dirt up onto the front of the engine.
I'm going to knock up a DIY sump guard that will hopefully cover the front of the engine, not just from road dirt but also from the larger lumps of stone that one might encounter when riding the dirt
A seperate thread with photo's will follow in due course
Steve T
Last Edit: February 15, 2020, 12:05:28 PM by Steve T
Logged
British Born
Raised in Wales
Living in Scotland
Still British 1st though
Pages: [
1
2
Go Up
harsh std suspension
Suspension
phattanglo
Today
at 09:02:07 AM
OEM Heated grips not working
QiqiRider
Today
at 08:34:10 AM
Thumb brake
CB500X - General Chat
AJC500
Today
at 08:24:17 AM
big foot she no fit
AJC500
Today
at 08:18:23 AM
Rear Rack
motorboy
Yesterday
at 09:47:22 PM
Rally Raid Level 1 Install & Impressions
Rally Raid
LightRider
Yesterday
at 08:59:54 PM
tires dimensions
Tyres and Wheels
Swanny
Yesterday
at 08:42:34 PM
Steering a little off after a drop?
Maintenance and Servicing
Mister Paul
Yesterday
at 07:50:10 PM
Happy New Year from France
New Member Introductions
o_ben
Yesterday
at 06:11:58 PM
Panniers Used With RR Soft Luggage
Rally Raid
LoneWallyUK
Yesterday
at 02:29:13 PM
