Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Speedo signal  (Read 436 times)
Offline richardbd
Re: Speedo signal
« Reply #10 on: February 04, 2020, 08:58:22 AM »
*Originally Posted by markking [+]
Thanks Richard, I'll keep an open mind re the sprocket then. 2-teeth down on the rear isn't as drastic as I've read some do on here which includes down 2 on the rear and up 1 on the front - blimey!  :033:
And as you found, the more I ride it the less I'm looking for 7th as well, and also I'm getting used to making sure I'm not in too-high a gear when exiting low speed corners - It don't drive smoothly from idle like a four-cylinder does - and the last twin I owned was an RD350LC in 1982.
Bet you wish youd kept that RD!
Offline markking
  • City / Town: Pulloxhill
Re: Speedo signal
« Reply #11 on: February 04, 2020, 11:09:35 AM »
*Originally Posted by richardbd [+]
Yes, but some bugger nicked it. It was only 6 months old.
YBH 637X - nobody seen it have they? - Luton area.
« Last Edit: February 04, 2020, 11:13:55 AM by markking »
Offline richardbd
Re: Speedo signal
« Reply #12 on: February 04, 2020, 11:16:03 AM »
 :745: :745:
Offline hilldweller
  • City / Town: Macclesfield
Re: Speedo signal
« Reply #13 on: February 04, 2020, 11:41:07 AM »
  It seems quite a few people do it and then quite a few of them revert to the original
As I posted the other day. One tooth seems to take the edge off what performance it had. I've not done any serious motorway miles to tell if there is a good benefit at high speed cruise but I feel it's changed quite a bit on normal A roads.
Of course these tests are hardly back to back and worse, it's winter so bigger gaps in riding. It's just gut feeling.
Brian.
Offline markking
Re: Speedo signal
« Reply #14 on: February 04, 2020, 11:48:24 AM »
Would that be one tooth on the front Brian?
Offline hilldweller
Re: Speedo signal
« Reply #15 on: February 04, 2020, 01:55:35 PM »
Yes. Easy option, no chain problems.
Brian.
