Author Topic: Locks  (Read 987 times)
Offline DMann
  • Bike: 2020 CB500X
Locks
on: May 28, 2020, 02:03:08 AM
Just a heads up, I was lubricating the locks on my panniers with graphite and figured I would hit the ignition and fuel tank locks at the same time. Everything was smooth as silk except the fuel tank lock, which would not turn at all. I had only opened the tank one time before so I was thinking that something was left inside from the factory and flaked off when I fueled up. The compressor was full so I shot some air down the key slot and tried again, it opened fine. I thought I might as well lube it up so I gave it some more graphite. I go to test my handiwork and again the key would not turn. The powdered graphite was my problem. I think the powder would not let the key go in all the way. I am glad I tried the air before I started taking things apart. Hope this helps someone.
Re: Locks
Reply #1 on: May 28, 2020, 02:18:12 AM
Good to know!
Offline Lancs-lad
Re: Locks
Reply #2 on: May 28, 2020, 09:02:35 AM
Did you “dust” the key with graphite powder or squirt it into the lock, I’ve found that lightly dusting the key is the best way?
Red Rose Classic MCC
Re: Locks
Reply #3 on: May 28, 2020, 09:45:32 AM
What's wrong with a wee spray of oil??   :034:
2017-2019: 12000 miles recreational use - 89.73mpg UK; 74.72mpg US; 3.15litres/100km
Re: Locks
Reply #4 on: May 28, 2020, 10:25:03 AM
Oil just attracts dust and clogs up...only need a bit of pocket fluff stuck to a key sticking to oil over a period of time to get a lock sticking.
Best lock lubes are dry, often graphite based.
Offline Lancs-lad
Re: Locks
Reply #5 on: May 28, 2020, 10:58:19 AM
Locks with pins need graphite powder & never ever use WD40 as stated by Oyley oil attracts dust which clogs the lock, see it many a time when I was Joinering old dears loved squirting 3 in 1 in Yale locks :008:
Re: Locks
Reply #6 on: May 28, 2020, 11:33:04 AM
That's a fact....years ago with big old mortice locks one could get away with a bit of thin oil like 3 in 1...for a while but if you ever dismantled one those levers would be well gummed up...mortice lock keys would easily pick cotton an other picked debris up and deposit it inside a lock.
Our modern bike keys dont pick debris up as easily but the style of locks are more sensitive to clogging and they are in a harsh environment and any dust setting on the outside of the lock is only going to be forced into the lock on repeated use.
If you add a lubricant that attracts dust,a grain of sand etc..its only going to make things worse.
Stick to dry lubes ...
Re: Locks
Reply #7 on: May 28, 2020, 11:43:51 AM
Can't believe I'm being told not to use oil by someone called Oyley!!! :008: :008: :008:
Re: Locks
Reply #8 on: May 28, 2020, 11:49:30 AM
I would not tell you to not use it...but if suggested to use it and your lock failed you...well.
Yeah..dont let me anywhere near your locks  :087:
It was a nickname from many years ago that has stuck..get that? Stuck.
Its derived from my surname ..
Oyley Royley was how it started out.
Re: Locks
Reply #9 on: May 28, 2020, 12:11:11 PM
I'm just kidding around!
